Motor Fried
#22
RE: Motor Fried
Wow that sucks! Like others said my first quest would be to see what the hell happened. There's no reason for your car to die like that at 60k miles! I know people that are past 150k miles with full bolt ons & nitrous who have no problems.
Maybe someone sabotaged your car. Just a thought.
#25
RE: Motor Fried
ORIGINAL: 2002GTAUTOVERT
i dont think that would do it.. i think forgetting to put oil IN would do it...
ORIGINAL: swooshonln
did you forget to change your oil??
Motor blew at 60k?? Possible... if the oil was bad or low, if it was redlined enouph,... especially on bad oil... if it overheated... got oil? got water? Got antifreeze?
#26
RE: Motor Fried
im thinkin ur gunna need the whole new motor ooba...there were 2 qts of oil when u drained it after and i think thats from when it overheated a couple months ago and could have burnt the rings...it has been smokin when u got on it since then u kno?...only thing that i dont get is why the oil level was fine when u checked it a week ago
#28
RE: Motor Fried
ORIGINAL: Hyper00
What recent mods have you done? ...or maintenance?
#29
RE: Motor Fried
Check the crank like somebody mentioned earlier. If you can turn it then the motor is not seizedand you may find the culprit by visually re-doing the installation.
However, if it cannot turn then the motor is seized. That could be from numerous reasons, i.e. anything fromhydro-lock to bad fuel. In that case,you won't know until you open it up.
#30
RE: Motor Fried
Well, I don't know if you'd need a shortblock or longblock, but this is a good deal:
http://www.modularmustangracing.com/...hortblocks.htm
