im buring so much oil.
Old Sep 14, 2007 | 09:40 AM
SVTBill's Avatar
SVTBill
Default im buring so much oil.
400 miles and i burned a quart
WTF 46,600.1 miles
im on my way to go get some oil from autozone
why is it burning so much? sae5w-20 synthetic blend (motor craft) with a fram filter
please help
are my rings bad or something?!~
Old Sep 14, 2007 | 10:00 AM
ponysnake99's Avatar
ponysnake99
Default RE: im buring so much oil.
check to make sure you don't have bits of oil in your coolant resevior, and also check the fluid on your dipstick to make sure it isnt sweet smelling or milky looking. this could be signs of some serious problems.
Before you start sweatin' buckets, are you sure your oil pan plug is sealing properly and not cross threaded? Is your filter on tight and not damaged? When you checked your oil last, was the engine hot or cold? Can you see any oil deposits on/under the engine?
If you are burning oil this bad, there's one more test you can do. Check your spark plugs, burning oil will leave deposits on the electrodes, leaving a shinny black or gunky substance on them.
Old Sep 14, 2007 | 10:12 AM
SVTBill's Avatar
SVTBill
i meant to say i just got done changing my oil about 500 miles ago, i checked it this morning (about to go on a trip) and saw how low it was...no coolant mixed, the filter is on tight and the oil pan bolt isnt cross threaded (i change it myself)
how on god's green earth do i get to my plugs on this engine? LOL
thanks for your help man
Old Sep 14, 2007 | 10:29 AM
SVTBill's Avatar
SVTBill
i checked the oil when the car was cold, am i supposed to check it when the car is hot?
Old Sep 14, 2007 | 10:39 AM
ponysnake99
no its better to check it cold, asking if u checked it hot or cold was to make sure you didnt check it after running it. Checking your oil level after riding around gives lower than normal readings because some of the oil is still covering parts on the top end of the engine. If you checked it cold then it rules out this "mis-reading".
As for spark plugs, i've never changed them on a GT, but im sure a good extension and a spark 5/8" is all you need
Old Sep 14, 2007 | 10:46 AM
SVTBill's Avatar
SVTBill
thanks bud
anything else i should check out before the trip?
yesterday i rebalanced all my tires, i put washer fluid in (most importatnt thing, i know), i checked the air filter
hmm what else?
Old Sep 14, 2007 | 11:56 AM
swooshonln's Avatar
swooshonln
do you notice any black smoke (or any kind for that matter) comming out of your exaust when your car is on? what about if you get on it, do you see any then?
Old Sep 14, 2007 | 12:26 PM
MrChubs1's Avatar
MrChubs1
ORIGINAL: ponysnake99
I have to disagree here. The level you want in the pan iin a perfect world is at the full mark on the dipstick with the engine running. Since you can't get an accurate reading withit running, you gotta shut it off, but check it right away while it's hot and you have some oil up top still.
That said, it's not that critical. It's better to be slightly low on oil (like zero to 1 qt range) than to be overfull.
Old Sep 14, 2007 | 12:47 PM
SVTBill's Avatar
SVTBill
really? how is that true, if its over full wont it just burn the excess off?
i just added a quart and a half a little while ago
that puts me at 9 1/2 quarts
just kidding
but seriously, i should be up around 5 1/2 now
sometimes not often at all i will see white smoke coming from the exhaust at a light...like 1-2 times a month, it will do it at 1 light only, but when it does it its like a ton
wtf?
its only happened like twice actually
in about 1 hour im leaving for that trip, anything else i should check before i skedaddle?
Old Sep 14, 2007 | 01:58 PM
Fobra's Avatar
Fobra
Banned
you probly counted wrong... 51/2 is not enough oil bud - 4.6's can take 6 to 6.5 to read full - i know it sucks
