FLUIDYNE WITH ELECTRIC FAN
ON THE CAR LISTED BELOW
I want to put a fluidyne radiator and with an electric fan but my question is
does the fan really make a big diffrence? and if so which fans are the best ?
i was looking at a 14inch mushimoto american muscle anyone know of a better one?
RE: FLUIDYNE WITH ELECTRIC FAN
stock is sufficient as racer02GT said, and if you bought the replacement fluidyne, than the support brackets should be on the walls of the radiator already, making the stocker an easy drop in. If you want a little betterperformance and maybe a little more assurance with your cooling ability out of the stock fan, get a 180* thermostat and change your fanrpms to be on longer/run at higher rpms themselves (using a tuner), allowing the fluid cooling inside the radiator to disipate more heat, quicker.
you feel you'd be better off buying a fan, getone that flows the most cfm and a pull-through design.
Seanam
10-04-2015 10:15 AM
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
