clutch problems
i would definitley go Spec, i live in el paso texas, the home of texas hot rods, and thats what they recommend 100% of the time. stage 3 is overkill for bone stock and even mildly modified. if you actually get a blower, stage three is the way to go, but if you're not sure, go stage 1 or 2.
my gt is stock minus a cai, and i'm only getting a stage 1 spec. it holds 400-450 hp i do believe, about the same for torque/ft lbs. and i agree with whoever said it above, stage three from everyone i've talked to (not personal experience) you will lose some street drivability.
ORIGINAL: Stonewall83
ok so last night i tried to smoke the tires
i was told to do it in 2nd gear so i wouldn over rev the motor.. i revved it up to about 4k and dumped the clutch it barely moved and all i could smell was burnt *** clutch?? is it worn out?? also when i did it in 1st gear it spun the tires and when i shifted it made the same clutch smell?? anybody else have this happen to them????
thanks fellas
Charlie Williams
thanks fellas
Charlie Williams
If the clutch is slipping it's either worn out or out of adjustment.
You need to realize that clutches are rated at torque levels, not hp. A Spec stage 2 will be just fine at 550 rwtq. and have the same pedal compression feel as a stock clutch but will engage quite a bit "firmer". By that I mean, you're not going to be able to "slip" a Spec 2 like a factory clutch.
A Spec 2 is all you'll need on 95% of the GT cars on this forum. Stage 2+ will take care of the other 4%.
Some of the Cobra guys and the 1% of the GT guys may need to go with a stage 3 or 3+, but that's about it.
Unless you're putting down to the rears 600+ rwtq, a stage 2 or 2+ is all you'll need.
thats exactly what I was asking
thanks
and I just got new tires and was gonna burn the old ones down a bit but ended up burning the clutch I think! lol
actually it runs just fine
also... I was told a couple times on here that 2nd gear is the best gear for burnouts because 1st is so low it just revs like hell???
thanks
thanks
thanks
centerforce stage II will hold 200 HP of NOS on any engine you build and 26 in. slicks no problem seen it done! a buddy of mine spent $7000 on a 5.0 biult by a performance shope in PC Florida set up for 250 HP of NOS and the slick it hooks and doesn't slip the clutch.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
