well whats the best way to go about this? intake manifold.
Well i picked up my 99 mustang this summer knowing nothing about the ****ty plastic intake manifolds and the other day it cracked! Now it looks like im **** outta luck right? all the warrantys and what not are all done i believe. So is there any hope or at least whats the best way to go about this? i found a brand new intake manifold for around 200 bucks and another 200+ to get it installed. Now is there any better way to go about it? is it something easy to do that i could install myself or should i have it done right by ford? lets just say this sucks... is there anything else i should do while its apart. Well lemme know what to do guys im so pissed this is coming outta my s/c fund!!! bastards
**edit: Subject edited, please do not circumvent the swear filters. Sorry
RE: f*ck.. well whats the best way to go about this? intake manifold.
americanmuscle has the intake manifold and yea its deff plastic and dont waste money on labor its really easy to take off i did my heads and cams which obviously require the removal of the intake manifold and that was the easiest part. and remember i never took apart a motor before lol
why not just fork out the cash and get a performance intake (like a cai) then the problem is fixed and you've got an enginemod.
ORIGINAL: 02 GT
B) a cold air intake is TOTALLY different from the intake manifold, which is what the op is talking about
to the op, just do the manifold yourself, its really not that too difficult, just find a good writeup
Its really not that hard to install it shouldnt take too long. I had more trouble getting my valve covers off than my intake lol.Might just be me though.
Make sure you get Genuine Ford parts. Dorman makes an intake as well for the mustangs and it's garbage. The port holes are all closed up. I had to open mine up with a dremel. I was pissed. It's quite a bit of work if you don't know what you are doing. You have to unplug all electrical on the top of the motor. Take the alternator off, unbolt the fuel rail (unplug the trunk switchin the trunk...hold a towel over the schrader valve to relieve the fuel pressure.)(shcrader valve looks like a a tire valve stem to put air in) Folt the fuel rail out of the way. Take the injectors out and wipe o-rings clean. You have to clean up the head surfaces and make sure you don't push all the settled dirt into the port holes in the heads!!!!! I ziptied the wiring harness to the wiper blades to hol it up and back and slide the intake through the front. Instal is a breeze.
https://mustangforums.com/m_3833004/tm.htm
here ya go, this is a swap from an NPI motor to a PI motor, you won't need all the parts listed but its pretty much teh same procedure.! enjoy
