squeaking
Old Sep 24, 2007 | 05:42 PM
stang4life05's Avatar
stang4life05
Default squeaking
ive got an 01 GT and when i hit bumps i get some squeaking noises, just wonderin what it might be and if its an easy fix...figured it was something with the springs/shocks, sorry if my vagueness doesn't help
Old Sep 24, 2007 | 06:36 PM
kingofqueenz's Avatar
kingofqueenz
Default RE: squeaking
i have the same problem with my 2004 gt.....when i hit potholes or speedbumps there is a really annoying squeeking sound.....i also get the same squeeking sound when i accelerate....i can't figure out where its coming from....i have 47k miles so i would think my shocks and springs shouldn't be squeeking that much....
Old Sep 24, 2007 | 06:40 PM
mfj's Avatar
mfj
Banned
use some wd 40 my friends!!
Old Sep 24, 2007 | 06:46 PM
josh.davis's Avatar
josh.davis
yeah, i had the same problem. I just WD 40 everything around my rear end.
Old Sep 24, 2007 | 07:00 PM
AJ06GT's Avatar
AJ06GT
My exhaust rubs my fuel tank a little on hard turns and squeeks... some day I'll get down there and actually fix that. But my car does squeek a bit in the rear suspension... It's about time for suspension rebuild anyway though, so I'm just dealing with it for now to see if that fixes it.
Old Sep 24, 2007 | 07:13 PM
GhostRider02GT's Avatar
GhostRider02GT
the stock struts are good for oh about 20k miles, that and the rubber bushings for all the control arms blow big kahunas.
Old Sep 24, 2007 | 09:34 PM
TX97GT's Avatar
TX97GT
my bushings don't look so great.. How hard would it be to swap those out?
[/align]
Old Sep 24, 2007 | 09:38 PM
96gtchinook's Avatar
96gtchinook
check control arm bushings, they are terrible stock upgrade to polyurethane. Not hard to do yourself, just time consuming.
Old Sep 24, 2007 | 09:58 PM
kingofqueenz
so what should i change or do to eliminate that annoying squeek? does it happen to you guys when u accelerate also, or is that just me?
Old Sep 24, 2007 | 11:50 PM
stang4life05
i don't notice it when i accelerate but my exhaust is pretty loud to cover it up but its very noticeable on bumps and stuff...as far as the wd-40, where at? everywhere or just in certain spots?
