T-45 swap
Old Sep 24, 2007 | 08:26 PM
arcticman37's Avatar
arcticman37
Default T-45 swap
I am going to attempt swapping my tranny out for a new one. (another T-45...I know shoulda gotta something better) But anyways I dont plan on changing the clutch because the one in my car dosent have more than 1,000 miles on it. I do think that the flywheel will be replaced though. I have read as many HOW TO's I could possibly read. I just want to know the chances that I will screw something up, what are some key pointsI should pay carefull attention to, what parts do I need to grease...Just anything you could comment on would be appreciated!!!
The car is a 1999 GT By the way...
Old Sep 24, 2007 | 08:53 PM
Mark99GT's Avatar
Mark99GT
Default RE: T-45 swap
How old is your TOB? What kind of clutch is in there now? Why do you want a new flywheel? There's not much to the swap. Grease the input shaft where the TOB rides on it, thefingers on the clutchfork that hold the TOBand the pivot point the fork sits in.
If you do the flywheel, you need to remove the clutch. Its pretty straightforward. Just slowly andevenlyloosen the pressure plate bolts from theflyweel so you dont damage the pressure plate. Then remove the flywheel. Installation is the reverse of removal.Youll need an alignment tool and some loctite to put it back togetherand you should probably do the pilot bearing while you're in there.
Old Sep 24, 2007 | 08:58 PM
arcticman37
Its an OEM clutch (TOB replaced with clutch), when I had it replaced the person (moron) who installed it told me that the flywheel was stress cracked......after he had reassembled everything. I might just wait for some more funds and throw in a King Cobra while I'm at it. Also waht type of grease should I use?
Old Sep 24, 2007 | 09:54 PM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
You want an FRPP king cobra for cheep? I'm swapping to a spec stg 3 for the blower so... I'll sell it to you for 40 bucks plus ship? Only has about 3000 or so miles on it. Pressure plate and disc only I believe the TOB is bad.
Old Sep 24, 2007 | 09:55 PM
arcticman37
Im not sure, how long before you will have it out?? Could you please send some pics to arcticman37@yahoo.com Thanks!
Old Sep 24, 2007 | 10:06 PM
35thAnni99GT
Will be out hopefully tommorow or wednesday. I'm swapping to a stronger T-45R and installing my blower too so I'll make sure to take pics of the clutch.
Old Sep 24, 2007 | 10:19 PM
arcticman37
Thanks I'll be in touch
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
