Installing new fuel rails.
Old Sep 27, 2007 | 06:23 AM
wwmost's Avatar
wwmost
Default Installing new fuel rails.
i got 01 fuel rails i need to install on my 04 because i need the schrader valve. any special tools i need or anything i need to know before i do it? it looks pretty straight forwared, havnt really taken a good look at it though. i guess i will just kill the fuel pump and let it run till it dies to loose all fuel pressurethen take them off. anything else?
Old Sep 27, 2007 | 08:43 PM
StangManEd's Avatar
StangManEd
Default RE: Installing new fuel rails.
You will need a 5/8"fuel line disconnect tool - $5 at an autoparts store
Old Sep 27, 2007 | 10:29 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
It may be different on my car because it's a return system, but the fuel lines were two different sizes. I don't remember what sizes, I can tell you it was the blue one and the white one!
Old Sep 27, 2007 | 11:48 PM
02TTGT's Avatar
02TTGT
instead of letting the fuel pump run there is what looks like a valve stem cap on the front of the passenger side fuel rail, take the cap off and cover it with a rag while pushing down the nipple, this will deplete the pressure in the fuel sytstem, or just leave the gas cap off for 30 minutes, whatever works, also make sure all the o-rings are still on the injectors
Old Sep 28, 2007 | 12:07 AM
arcticman37's Avatar
arcticman37
Id say go with turning the fuel pump off and letting it run out but yea like they said just get a fuel-line dicsonnect and that should be it. It should be a fairly fast and easy job, good luck.
Old Sep 28, 2007 | 05:59 AM
wwmost's Avatar
wwmost
ORIGINAL: 02TTGT
i dont have a schrader valve. thats the reason im switching my 04 fuel rails out for some 01 fuel rails because i need the valve for my nitrous. anyone want to buy some 04 fuel rails?
Old Sep 28, 2007 | 10:28 AM
DTK's Avatar
DTK
Can't help with the fuel rail install but here is a little blurb on killing the fuel pressure.
Bulletin: Discontinued fuel pressure relief valve (Schrader Valve)
2003 Mustang equipped 3.8 and 4.6 2V/4V built after Sept. 15 will no longer have the fuel pressure relief valve (Schrader Valve).
New Service procedure for relieving fuel pressure:
1. Remove the fuel pump relay or fuse in the engine compartment fuse box, refer to chart listed in this TSB for fuse location.
2. Start the engine and allow idling until the engine stalls.
3. After the engine stalls, crank the engine for about five seconds to ensure that the fuel injection supply manifold pressure has been released.
4. When fuel system service is complete, install fuel pump relay or fuse.
5. Cycle key and wait three seconds to re-pressurize the fuel system. Check for leaks before starting engine.
Note: It may take more than one key cycle to re-pressurize the fuel system.
6. Start engine and check for leaks.
Note: It is possible that a DTC may be set due to the pump relay being pulled and the engine started and run out of fuel. If DTC’s are set, clear all DTC’s before returning the vehicle to the customer.
Old Sep 28, 2007 | 12:48 PM
wwmost's Avatar
wwmost
what fuse number is that?
Old Sep 28, 2007 | 01:06 PM
josh.davis's Avatar
josh.davis
I am trying to put nos kit on my car. I have everthing fiqured out but how to tie into the schrader valve. Its a 99, so all i really need is to find the adapter for it.
Old Oct 4, 2007 | 06:44 PM
ponyman1969's Avatar
ponyman1969
what kind of fuel rails did you go with? you should be able to buy an adapter and put the valve there.
[IMG]local://upfiles/81256/54D511A57F9F4976A6FF820E3B53FF1A.jpg[/IMG]
Granatelli Sales
Jan 20, 2020 12:34 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
