Transgo shift kit installed
This is f**king awesome! The car accelerates much quicker now and the shifts are perfect. OD upshifting and downshifting is much better now. When shifting manually the shifts are so responsive. It feels so much better than what you do with a programer. I recomend this to all you automatics guys out there. I did the job myself and it is easy it just takes time.
RE: Transgo shift kit installed
Sweet. I'm gonna get one at the time I put in a torque converter and cooler. How do you like your stall? I was considering a little higher, like a 3300 or so. What kind of tires do you run? Any track times?
so what are your shift points before the shift kit and after
i noticed mine are around 1-2 is 27 mph 2-3 is 30-32 and 3-od is 38-40
does this sound the same to you? whats the difference after the shift kit if any?
Its pain in d *** to install yourself. If ur not a mechanic let it be installed by d pros. U gotap unch bunch of little pellet ballls into place its just pain man. Take it d shop . I learned d lessond hardx way lol and yes its a great mod
ORIGINAL: onegreedy
You know i havent paid attention to that actually
ORIGINAL: Adam03GT
What exactly does the install require that you do?
