AC PROBLEM
Old Sep 27, 2007 | 05:47 PM
fast929rr's Avatar
fast929rr
Default AC PROBLEM
The ac in my 96 gt is comming out of the defroster and it just started yesterday what can i check
Old Sep 27, 2007 | 10:34 PM
m1950's Avatar
m1950
Default RE: AC PROBLEM
there are some vaccuum hoses behind the stereo check there especially if you had some stereo work done the hoses i believe are yellow blue red and black
Old Sep 28, 2007 | 06:12 PM
InferRedd's Avatar
InferRedd
Also mine cracked underneath the hood right against the firewall. The hoses are really small. All I did was cut the hose right before the crack and scootched it to fit the plug.No big deal beside trying to find the damn crack.
Old Sep 30, 2007 | 10:55 AM
fr8flyer's Avatar
fr8flyer
Ford designed the a/c system to fail to the defrosters to prvent the windows from getting fogged up in case vacuum was lost to the system. On your firewall (passengers side) where your a/c freon lines go into the interior is a small vacuum line that goes to the vacuum accumulator, this line is probably broke. It is made of plastic where it goes thru the firewall. Ford does not sell a replacement, neither does Napa, Auto Zone or Advanced. The Ford dealer told me to replace it with a rubber vacuum line. I repaired mine by using a rubber vacuum line and placing over the two ends of the plastic line and pushing them in till they touched. To find where it connects to the accumulator (black, cylinder shaped) you will have to remove your glovebox and reach way up near the top, almost to the dashboard.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
