coolant issues
Old Feb 20, 2005 | 05:17 PM
mustang_montana's Avatar
mustang_montana
Default coolant issues
the coolant reservoir on my 96 gt overflowed with the cap still on tight. im guessing too much pressure? the coolant has been leaking a bit at the radiator too. im figuring the thermostat is blown , which sucks cause the heat doesnt work so i freeze my **** off in the morning. any feedback or advice? thanks a lot.
Old Feb 20, 2005 | 07:00 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: coolant issues
Get a new thermostat and keep an eye on the radiator and coolant level until its time to buy a new one. LOL If I were you I would give it a good flush also.
Old Feb 20, 2005 | 07:55 PM
mustang_montana
yeah i replaced the thermostat a half hour ago, i got heat again! everything seems alright, but im sure that leak off the radiator is still there. ill definetly be flushing the coolant along with replacing the water pump and other junk before that stuff goes.
Old Feb 20, 2005 | 07:58 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Make sure you are using coolant because that also lubs the water pump. If you dont then you can break the propeller shaft. Ive been there and done that. LOL
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
wraith777
Sep 28, 2015 10:49 AM
