Cobra Brake Upgrade and Bullets Rims?
Old 10-03-2007, 09:03 PM
Mustang_NTriangle
Mustang_NTriangle's Avatar
Default Cobra Brake Upgrade and Bullets Rims?
I decided to upgrade my front brakes to Cobra 13" rotors and calpers and will be getting saleen "18 wheels in spring. My question is will my stock 17" rims fit with the Cobra front calpers? I wanted to use these stock bullet rims for winter tires.
Thanks in advance.
Mustang_NTriangle is offline
Old 10-03-2007, 09:21 PM
undecided.steve
undecided.steve's Avatar
Default RE: Cobra Brake Upgrade and Bullets Rims?
ORIGINAL: Mustang_NTriangle
Thanks in advance.
I have been told YES they do, however those rims come in 6.12 or 5.72 backspacing so I am not positive if the 5.72 backspacing will fit.
The FRPP catalog is very vague about this.
undecided.steve is offline
Old 10-03-2007, 09:24 PM
Mustang_NTriangle
Has anyone else tried this? I have an early '03.I hope they fit so i do not have to sell them as i want them for snows.
Old 10-03-2007, 09:26 PM
ponyman1969
ponyman1969's Avatar
i dont think so, i have the m-2300 r kit. its on my 99 gt. i remember something about the stock rims not working, definitly the spare wont work. i was upgrading to better rims anyway(just like your going to do) so i would get your 18's
ponyman1969 is offline
Old 10-03-2007, 11:42 PM
ShadowDrake
ShadowDrake's Avatar
I have the stock bullitts (04) and they fit fine. It's VERY close though, caliper to wheel clearance is as low as 3/4"... and caliper to spoke clearance is probably about half that.
The tight fit looks good:
ShadowDrake is offline
Old 10-03-2007, 11:45 PM
65mojoe
65mojoe's Avatar
ORIGINAL: ShadowDrake
+1, I am running the cobra brakes on my '04 with stock bullitts, and while it is a TIGHT fit, everything clears fine.
65mojoe is offline
Old 10-03-2007, 11:51 PM
racer02GTstang
racer02GTstang's Avatar
yea, i have the same setup. it actually looks very good because it looks like your brakes are HUGE since they fill the entire inside of the rim.
racer02GTstang is offline
Old 10-04-2007, 02:49 AM
2000GT4.6
2000GT4.6's Avatar
Mine fit on my 9 inch bullits as well. Hell, its a STOCK bullit rim.. and the brakes come stock on the bullitt stangs.
One thing to keep in mind, unless you want to be swapping wheel studs and running spacers (huge hassle) you will not be able to swap on a 15 inch drag racing rim on the front if you want to go to the strip.
The brakes are worth it though, x10 better than stock 11.xx crap.
2000GT4.6 is offline
Old 10-04-2007, 04:19 AM
rogerwilco357
rogerwilco357's Avatar
are the front calipers and the rear the same size?
rogerwilco357 is offline
Old 10-04-2007, 10:39 AM
ShadowDrake
ORIGINAL: rogerwilco357
The rear is 100% the same. I do not suggest swapping the rear, it's not worth the hassle.
The front calipers are different, and allow the larger rotor to fit.
Quick Reply: Cobra Brake Upgrade and Bullets Rims?
