My chin spoiler is a little off!! F**K!
I installed a chin for the first time and it didnt fit right. So had to redo it. The second time I drilled and used the push pins I work my way from side to side up the the middle.It looks better but this time it doesnt line up perfectly with where the wheel well is. Its off by like a cm or2. It doesnt look bad but it still bothers me. Should I redrillholesin the chinand by new pins to redo it again since I alreadymessed it up??? I would appreciate your advice.
RE: My chin spoiler is a little off!! F**K!
That's your decision man. I know that even if most others can't tell, it still bothers you cause it's on YOUR car and YOU know about it. The only thing is those chins can get a little expensive, if I'm not wrong isn't it like 150? Send pics if you can of it on. If not, good luck then man.
thats how they all are. even mach 1's are like that. you cant have it line up on the wheel wheels and even around the front of the bumper at the same time. its stupid i know.
i think all the chin spoilers will be off a lil either on one side or equally off on both depending how you put it on...
no worries.. i'll feel you pain in a couple days when i put mine on.
Maybe I dont understand correctly, but the chin spoiler is actually not supposed to be completely flush with the front bumper. But the sides of the chin spoiler are supposed to be flush with the well. Its supposed to be flush for a while on the sides then recedes in just a little bit as it goes towards the front of the bumper. I'm not sure if thats what you were having trouble with or if you were installing it correctly. Maybe there is something else wrong, but this is how I think its supposed to be done.
