MIL problems
Old Oct 4, 2007 | 08:18 PM
96gtchinook's Avatar
96gtchinook
Default RE: MIL problems
mines a 96 and they work, my computer says DUHRRRRR!
Old Oct 6, 2007 | 12:20 AM
handyandy's Avatar
handyandy
So I just did what the instructions said that came with them: disconnect negative terminal of battery, (took out my old ones), then put the new ones in, then reconnected battery, and started it up. And sure enough the light went away, without even having to clear my codes! I thought since the computer saves codes until cleared even though the problems fixed it would come on. But I guess not. So badass. Thats what I get for following instructions
Old Oct 6, 2007 | 05:50 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
A number of faults are held as "pending" before they become stored in non-volatile memory--this means that the fault has not been observed for long enough for the PCM to be convinced it's real. Most all code readers will let you view these pending codes...[/align]
Old Oct 6, 2007 | 04:29 PM
handyandy's Avatar
handyandy
What are you trying to say? ..... does this mean my light is gonna come on pretty soon?
Old Oct 6, 2007 | 05:17 PM
jrherald420's Avatar
jrherald420
maybe..........maybe not............
Old Oct 7, 2007 | 08:34 AM
handyandy's Avatar
handyandy
alright.....?
Old Oct 7, 2007 | 10:44 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: handyandy
[/align][/align]If the MIL eliminators do their job it shouldn't--pending codes for non-critical and/or potential problems are stored in the KAM memory and if the situation corrects itself the are cleared after a while. The fact that resetting the KAM by disconnecting the battery cleared the code means that the code it had not yet been "latched" into the non-volatile RAM. [/align][/align]If the new MIL eliminators are indeedworking correctly the light probably would have gone out after you drove awhile, even without disconnecting the battery.Often afailing but not yet dead O2 sensor will sometimes trigger the SES lamp, then go away for a bit, and then come back... until the sensor actually dies.[/align]
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
trashxtrash
Sep 20, 2015 10:49 PM
