what risk's?
RE: what risk's?
ORIGINAL: 2002GTAUTOVERT
everyone has done stupid **** before, and believe me ive done my fair share. and ive seen what can happen when that 1 time it goes terribly wrong. our point is yes.. you did 1 stupid thing and got away with it just as we did.. learn from it and dont do it again. though ive never put it in reverse while going forward before.
ORIGINAL: 99 GT vert
i will admit it i have done the same thing when i first put my cat back on i went to put it in neutral and i went to reverse at about 20 and my tranny is still fine but i learned the i have to look when i go to put it in neutral
RE: what risk's?
When I was younger, I had a 1970 Torino 500 that had an auto with a 302. I had a tach, so I did alot of manual shifting.(Column shift)
One time, going from 2nd to 3rd, I went past N, and into reverse at about50-60 mph for about 1 second, until I pulled it back down into 3rd.
It didn't do any damage but the tires squealed and the car shuddered. Scarred the s#*t out of me.
RE: what risk's?
ORIGINAL: MU71L4710N
umm if i remember right you have to have your foot touching the brake atleast enuff to have the brake lights on in order to get the car into reverse so im guessing were not hearing the whole story to this (unless he was braking while trying to rev)
reguardless...i dont know ALL the risks...but somethings gonna break doing that. if it dont sound good...something isnt liking it. wheather its the tranny, the drivetrain, i dont know but somethings gonna give out if u do that enuff.
RE: what risk's?
most newer cars have a safty where if u put the car in reverse from nutral it will over ride and nothing will hapen. what happens tho in an auto trans the gears will be going one way (forward) and as soon as it goe into reverse the gears inside will change up the some of the forward gears will no longer be ingadge but the big gear (sun gear) its the one that makes the car run will grab the revers gears and that will mess some stuff up if doen enough times
RE: what risk's?
on top of all the crap i just gave you and your buddy.. reving your engine in neutral = SPUN ROD BEARING... if that happens plan on a new motor.
RE: what risk's?
ORIGINAL: BigRed03GT
really? i never knew that reving ur car in neutral is bad and a potential danger. i know people who's been doin that for years.
RE: what risk's?
as long as you have oil pressure and your motor isnt overheating and your not bouncing off the rev limiter there is nothing wrong with revving your motor. that is absolutley the most rediculous thing i have ever heard.
RE: what risk's?
ORIGINAL: livefast1
And for the record.. the most ridiculous thing ive heard is the gains from an electric supercharger.
RE: what risk's?
hes jus talking about piping somebody, completely different from missing a gear and over revving your motor. and if you are truely in nuetral or at a dead stop its almost impossible to over rev your motor, hence the invention of the rev limiter. but all arguments aside yes electric superchargers are ridiculous.
RE: what risk's?
youre right its ridiculous.. like when you over-rev by missing a gear and spin a bearing. the reason you rev up higher in neutral and faster, is there is no load for the energy to be transferred on (the tires) so where do you think it goes? you think it magically disappears into your exhaust pipe or your ego? think about it. And once again, it depends on how high you take it.
ORIGINAL: livefast1
