Engine Problems!
Old Oct 15, 2007 | 09:12 AM
2000StangNP's Avatar
2000StangNP
Default Engine Problems!
Blown engine. will start but i believe i just blew a rod bearing.... What do you think...?? PLEASE NEED SUGGESTIONS THANKS!
Old Oct 15, 2007 | 09:44 AM
Fobra's Avatar
Fobra
Banned
Default RE: Engine Problems!
you need to post alot more info
Old Oct 15, 2007 | 09:48 AM
97targa's Avatar
97targa
ou don't "blow" rod bearings. You "blow" a rod itself, like out the side of your block! Does your engine knock bad? You know you can fix a bearing problem! As long as yuou haven't scorched it too bad, you can just throw another bearing in there. Not gonna say it will last you 100kmi, but it will give you time to save for a rebuild
Old Oct 15, 2007 | 11:53 AM
2002GTAUTOVERT's Avatar
2002GTAUTOVERT
yes you blew your engine, and it also sounds like, from your detailed description, that your tranny is definetly near the end.
Old Oct 15, 2007 | 12:13 PM
swooshonln's Avatar
swooshonln
ORIGINAL: 2002GTAUTOVERT
[sm=icon_rofl.gif]
haha. maby the trannys fine, he just forgot to put his front o2 sensors back in???
Old Oct 15, 2007 | 12:22 PM
X04Mach1X's Avatar
X04Mach1X
is this a joke? i bet you guys would have better luck guessing how many fingers im holding up right now
Old Oct 15, 2007 | 02:21 PM
MrChubs1's Avatar
MrChubs1
If you spun a rod bearing and drove it for any distance at all, you'll probably ned to have the crank cleaned up. The bearing material will besically weld itself to the crank journal and make quite a mess. It'll also increase your chances of spinning the bearing again if you just stab another in there.
What caused it to spin? First step is to fix the problem.
Old Oct 15, 2007 | 02:44 PM
NeedStangSpeed's Avatar
NeedStangSpeed
Can somebody tell me the winning lottery numbers tonight too?
Old Oct 15, 2007 | 02:55 PM
2002GTAUTOVERT
ORIGINAL: NeedStangSpeed
why would i tell you ?? thats means youd get a cut of my winnings...
besides.. god told me and me only.. dont think he wants you to know!!
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
