hmm kinda worried about taking the panel off but i guess if wd40 doesnt do it for a while ill take it off. What about just replacing the weatherstripping?
Well, granted I haven't been in my passenger seat since I rode with the guy that I bought it from to see, but I don't think it's from the weather stripping. Window creaks are usually from the motor/gears. If that's not the case here then nothing I've said applies. [8D]
Are you guys talking about the crick sound or the sceeeeeeeeeeeeq sound?...the sceeeeeeeeeeeq sound is fron the little rubber piece by the 460 tweeter.
Oh really? Hmm... I'll have to check out where it's coming from sometime.
Yea if you just put wd or some kind of lube (lol) on the inside of the rubber piece it will go away..
Yeah, that's probably not the best place for something like lubriplate like I was mentioning earlier then. I can damn near promise you that it wont ever squeak again, but it's probably going to be pretty messy unless you're careful. I know I put my hand right about there when the window is down and I wouldn't want to get grease all over my finger every time I did. Let me look into that piece because I bet you can fab up a new piece to replace that rubber bit that's got a softer cloth that will slide easier and not make noise. (Haha, you and I are in OT enough to know this thread would be a goldmine over there with all this talk about lube and sliding easier)
Well it seems like it only makes this noise when the driver side window is rolled up. doesnt even have to be all the way. I only tested it with the rear triangle window thing up to. so maybe its the window moving around or something. I dont know but its kinda loud and annoying
clean in between the weatherstripping where the Mach 460 tweeter is. always fixes it for me,mine never squeeks anymore. there was a lot of black **** in there.
