symtums of water in engine via CAI?
what would the symtums be if i happened to sucksome water into the engine through my JLT cold air intake? cause my rpm's are all over the place after driving through a thunder storm this afternoon!!!!![:@] thanks
RE: symtums of water in engine via CAI?
Check your filter to see if it's wet. If it is the there is a really good chance you got some water in there. Chances are it messed up your maf if it did. I'd take the filter off and check for moisture in the pipe and maybe try to borrow a buddies maf to see if it fixes the problem.
