Grease the Steering Rack?
Old 10-15-2007, 06:17 AM
99GTvert
is my username.
99GTvert's Avatar
Default Grease the Steering Rack?
My steering wheel/rack squeaks every time I turn the wheel. I figure I just need to lube up something, but where exactly?
99GTvert is offline
Old 10-15-2007, 06:46 AM
AJ06GT
AJ06GT's Avatar
Default RE: Grease the Steering Rack?
Sounds like it could be a tie rod end, and if that's the case, no, you can't lube it, that's the entire problem. Ford put tie rod ends on these cars that couldn't be greased, so once they get older or get some dirt in them, you're screwed and have to replace them.
AJ06GT is offline
Old 10-15-2007, 08:47 AM
MineralGrey
MineralGrey's Avatar
Alot of cars are like that and a tie rod isn't all that expensive, you could get it done at shop easily for under 100 bucks.
MineralGrey is offline
Old 10-15-2007, 09:31 AM
AJ06GT
AJ06GT's Avatar
ORIGINAL: MineralGrey
Please, don't bring your car to a shop for tie rod ends. It's about a 10 minute job in your garage. Easiest thing I ever did on my 97.
AJ06GT is offline
Old 10-15-2007, 11:41 AM
99GTvert
is my username.
99GTvert's Avatar
Hmmm.
I figured it was something thta just needed lube, because this was noticable after I got my car back from a LT header install.
Anyone know of any write ups? I may as well diagnose the problem with a buddy, and if it is true, I'll replace it.
99GTvert is offline
Old 10-15-2007, 11:46 AM
Derf00
Gentleman's Relish
Derf00's Avatar
ORIGINAL: 99GTvert
Hmmm.
Check to make sure the R&P bushings are tight.They may have loosend thebushing mounts to give a little more wiggle room for the LTs. Grease the tie rods and silicone lube the rack bushings. Should take care of it.
Derf00 is offline
Old 10-15-2007, 11:48 AM
97targa
97targa's Avatar
F.ckin A I was wondering what th hell was squeeking! I thought it was my swaybar bushings so I changed them(had to anyways..I already bought them last year)Didn't help. I'll go and get some tierod ends! Awesome...WOW something I didn't know!
97targa is offline
Old 10-15-2007, 01:23 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
There's a TSB for this, it was one of the first things I corrected on my '03 GT--read more here...[/align]
cliffyk is offline
Old 10-15-2007, 01:27 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
ORIGINAL: AJ03SVT
+1 this was easier than installing a K&N filter
2002GTAUTOVERT is offline
Old 10-15-2007, 01:31 PM
Brute03
Brute03's Avatar
hey cliff, i used your write-up and modded the tube things for the steering rack, it worked like charm the creak is gone, thanks man!
Brute03 is offline
Quick Reply: Grease the Steering Rack?
