Speedometer Problem
Old Oct 18, 2007 | 06:15 PM
m16a2r's Avatar
m16a2r
Default Speedometer Problem
I have 1998 mustang gt that I got like a year ago, dont really know all the mods that have been done to it. I always had a problem with a speedometer being off by 5 miles, so if I drive 35mph it shows 40mph. I figured that I got some Gears installed by previous owner. Recently I got me a Diablo sport tuner and tried to change gear ratio, but diablo sport do not let me choose gears. So how can I find out if I have gears installed or not? And how can I fix speedometer problem? Thank you for responces in advance.
[align=left] [/align]
Old Oct 19, 2007 | 03:21 PM
m16a2r's Avatar
m16a2r
Default RE: Speedometer Problem
bump, maybe someone know something or not?
Old Oct 19, 2007 | 03:33 PM
GolfmanSpeck's Avatar
GolfmanSpeck
the speedometer is not controlled by the PCM, therefore you cannot change it with a tuner. The only way to fix the speedometer on thesn95s is to either get a speedcal from dallas mustang, or to change the speedo gear.
Does your car have gauge face overlays? If so, the needle could have been put in the wrong place with reinstalled. If it is a constant 5 mph off at all speeds, then I would imagine that this is your problem. If the car had different gears it would be off by a smaller amount at low speeds (say 2 mph) and more at higher speeds (say 10 mph).
Old Oct 20, 2007 | 12:04 AM
Ehmark's Avatar
Ehmark
+1
Old Oct 20, 2007 | 02:59 AM
adam_ferguson's Avatar
adam_ferguson
++1 if you have gears it will be an expontential increase through speeds. example : 20mph = 24 mph ...... 60mph = 75 mph.....etc.
Old Oct 20, 2007 | 10:48 AM
MineralGrey's Avatar
MineralGrey
+1
Old Oct 20, 2007 | 02:00 PM
m16a2r's Avatar
m16a2r
Thank you for your help
Old Oct 20, 2007 | 02:12 PM
m16a2r's Avatar
m16a2r
Oh by the way, one more question, is it any way to check if I have aftermarket gears installed?
Old Oct 20, 2007 | 05:42 PM
Ehmark's Avatar
Ehmark
How fast does your car go at 5000 rpms in 2nd?
Old Oct 20, 2007 | 09:20 PM
m16a2r's Avatar
m16a2r
will check it out tomorrow.
