Exhaust leak killing my fuel economy
Any ideas as to where typical exhuast leaks occur? I've got an O/R mid pipe, and a cat back on it now... when I put any kind of load on the engine it sounds like the exhaust is chugging out of some leak somewhere under the hood, and I get an exhaust smell in the cabin when I turn the fan on. Is it possible for their to be a leak in between the header and the block? I really dont know where else to look for it!
I'm only getting about 205 miles to a tank as well!!
any advice would be appreciated!
RE: Exhaust leak killing my fuel economy
Take a piece of water hose about 3 feet long and put one end up to your ear and use the other end next to the exhaust. (Don't touch it... rubber melts) You will find the general area of the leak. You will hear a totally different sound when you get near it. You should hear a ticking sound.
Cool man .... I was volentold to be a mortarman at first but I wanted to be an 11 and the only way I could get out of it was do 8th & I for 2 years.... so I stuck in D.C. for 2 years .. Witch isnt that bad. But I would rather be in the fleet
did you install a new gasket on the passenger side manifold? The driver side is the easier of the two to keep from leaking because of the ball and socket. The passenger side requires a gasket that sucks ***
ORIGINAL: sxynerd
Does a leak really affect MPG???
I also was a Marine 0331/0321
