5.4 intake adapters
Old Oct 24, 2007 | 08:44 PM
  #21
kshwannabe's Avatar
kshwannabe
Default RE: 5.4 intake adapters
what little thing do you have to switch that are not on the 4.6 or is it almost a direct bolt in replacment
Old Oct 24, 2007 | 09:42 PM
  #22
amoosenamedhank's Avatar
amoosenamedhank
The exhaust is different, depending on your intake the fuel rails are different. Most if it is plug and play.
Old Oct 24, 2007 | 09:51 PM
  #23
brent_cosenza's Avatar
brent_cosenza
use 4.6 exhaust manifolds or shortys, you have to plug or cap off the return line on the 5.4 fuel rail, i used the 4.6 mounts...you have to fab the power steering resevoir, extend some plugs like the TPS and IAC sensors just to name a few
Old Oct 24, 2007 | 09:52 PM
  #24
brent_cosenza
depending on your yr car 96-98 will need a new k-member
Old Oct 24, 2007 | 09:54 PM
  #25
amoosenamedhank
Well the fuel is going to differ in years. The 96-98 use a returnable fuel system so you don't need to plug anything.
Old Oct 24, 2007 | 09:55 PM
  #26
brent_cosenza
didnt think about that as i have a 01 expedition motor
Old Oct 24, 2007 | 10:05 PM
  #27
kshwannabe's Avatar
kshwannabe
what do you mean fab the p/s would i just have to drill another hole in the bracket. and i have the fuel rails for the p51 so they should bolt right up now will i still be able to have all my accsesories like a/c
Old Oct 24, 2007 | 10:47 PM
  #28
kshwannabe's Avatar
kshwannabe
can i use the 4.6 flywheel or do i need a 8 bolt cobra flywheel
Old Oct 24, 2007 | 10:56 PM
  #29
amoosenamedhank
ORIGINAL: kshwannabe
Some 4.6 use 8 bolt flywheels. I'm not positive but I think most/all 5.4 use a 8 bolt crank. I know mine did. With the power steer resevoir, the timing cover won't have a place to bolt on your coil pack and power steering reservoir. So you'll have to do something about that. I am switching to COP and making a bracket for the resiviour.
Old Oct 25, 2007 | 01:09 AM
  #30
brent_cosenza
8 bolt crank on the 5.4 and yes some of the earlier 4.6's had 8 bolt cranks...up until mid 01 i believe and you will have to cut the bracket and make new holes depending on the year and unless you can get adapter plates you wont be able to use the P51 5.4 intake is about 1-1 1/2 inch wider than 4.6 due to deck height
