cobra engine swap
Old Oct 26, 2007 | 01:39 AM
jst98gtmustang's Avatar
jst98gtmustang
Default cobra engine swap
Ok i was thinking of doing a cobra32v engine swap in my car,or just doing a pi swap to my motor,have not made up my mind yet.
but what i like to know is,what all do i have to do to change out the motor,could i use my trans?can i use my ecu?do i have to change out
the motor mounts or will the one for my NPI engine work?any info will help.Thanks
Old Oct 26, 2007 | 10:37 AM
xander0561's Avatar
xander0561
Default RE: cobra engine swap
There are a few guys on here that have done the swap and are very happy with it. The block is the same so you don't need new motor mounts, unless they are damaged then you'll need some new ones. The trans will mount up fine, but if I were you, I would get a set of nice ported and polished heads and a set of stage 1 cams. I'd say stage 2 but I dont know when we start to run into valve to piston contact with the NPI motors. With a good tune, and full bolt ons, you can really make some good hp numbers. Thats just my opinion.[&:]
Old Oct 26, 2007 | 11:04 AM
trickdriller's Avatar
trickdriller
Yeah man, if you can afford the 4v swap, do it! The PI swap is nice, but it just doensn't breathe like the 4v's do.
Old Oct 26, 2007 | 11:28 AM
Zanador's Avatar
Zanador
You would need the 4v engine, wiring harness, and cobra ECU. Everything else you can reuse, motor mount positions are the same etc. If you can find a good deal on a 4v engine it really is worth it- a 4v with bolt ons will make as much power as a 2v with H/C
Old Oct 26, 2007 | 02:54 PM
Fobra's Avatar
Fobra
Banned
you dont need a cobra ecu - just get urs flashed ... better yet tuned
Old Oct 26, 2007 | 02:58 PM
uberstang1's Avatar
uberstang1
Chupacabra
You can get ur gt ecu tuned, you will ned the IMRCs deleted in the 4v motor, gt t45 will work, you will need a new flywheel and clutch, correct throttle cable and wiring, car looks good btw, but cobra motor swap comes before cobra badges.
Old Oct 26, 2007 | 02:59 PM
uberstang1's Avatar
uberstang1
Chupacabra
cobra and gt motor mounts are the same btw
Old Oct 26, 2007 | 03:55 PM
jst98gtmustang
ORIGINAL: uberstang1
Thanks man.
Badges was on the car when i got it [sm=smiley17.gif]
Old Oct 26, 2007 | 04:35 PM
GT03 TJS's Avatar
GT03 TJS
unless you get an 03-04 cobra block....your limit is still around 450 rwhp before you start breaking rods and/or pistons.
in which case a lot of us2V guys with built motors and blower/juicewould still be spankin you
no matter what you do...if you want big numbers, you gotta start digging in the motor....so just try and find the cheapest route.....my .02
Old Oct 26, 2007 | 05:50 PM
uberstang1's Avatar
uberstang1
Chupacabra
its a hell of alot cheaper to do a 4v swap then do a motor build.......my swap cost me about 3 grand from scratch to driving on the road
