Which Cams should I get?
Old Oct 27, 2007 | 09:04 AM
Chopper's Avatar
Chopper
Default RE: Which Cams should I get?
I have a set of custom grind cams in my H-D Sportster that were supplied by the same company that did the P&P (Zippers Performance) and they make better power than the other off the shelf,mix and match,set up's.
Old Oct 27, 2007 | 09:44 AM
GhostRider02GT's Avatar
GhostRider02GT
get stage II H/Cs, get both, they work great in conjunction, at least thats what I am doing this winter. Dont know brand or if custom grind or what not yet, but I do know I am not getting comp stage IIs, MMR says you need notched pistons for valve clearance
Old Oct 27, 2007 | 10:17 AM
droptoppony's Avatar
droptoppony
You don't need notched pistons for any stage 2 cams if they are installed properly...MMR just wants to scare you and sell you more stuff.
Old Oct 27, 2007 | 10:18 AM
MustangMike8705's Avatar
MustangMike8705
Go VT stage II
Old Oct 27, 2007 | 11:06 AM
GhostRider02GT
ORIGINAL: droptoppony
they only say that with comp cams though
Old Oct 27, 2007 | 12:56 PM
ben790450's Avatar
ben790450
I ♥ Acer
Bigger isnt always better people. Smarter is better. Go with stage 1's unless you're getting new heads. Well shoot might as well get stage 3 cams right!?
Old Oct 27, 2007 | 01:13 PM
GhostRider02GT
tis true, stage IIIs move your powerband way up there, I think...
Old Oct 27, 2007 | 01:27 PM
03greyGT's Avatar
03greyGT
Im runnin VT stage 2s on stock heads and the car is streetable as ever. Granted I do have full boltons plus 4.10 gears. I dont drive the car everyday, but I easily could if I wanted to. Id go with Stage 2s and if you ever decide to do heads in the future you re already good to go on the cams...
Old Oct 27, 2007 | 04:41 PM
2004YellowStang's Avatar
2004YellowStang
Is there a site for the custom cams??
Old Oct 27, 2007 | 04:44 PM
01GT4.6's Avatar
01GT4.6
ORIGINAL: 2004YellowStang
www.modularpowerhouse.com ask for Tim
