Is my engine blown or what???? VID INSIDE
#21
RE: Is my engine blown or what???? VID INSIDE
ORIGINAL: oxfordgt
Your engine is making the same mine did at the same exact place. I thought it was the tentioner cause I couldnt hear it in the oil pan only on top of the engine. But guess what the oil pan is filled with oil which makes it hard to hear. I tore the engine down and every rod and main bearing was spun. Now I have a forged motor
#22
I just took my valve cover off on thrusday and I had that much slack on mine also. It's def not supposed to have that much slack. When I put the heads back together and the cams in back in april there was no slack in the timing chain.
#23
Sorry I cant watch the video. I'm in Iraq and on a government computer which won't let you look at stuff like that and ebay and myspace[:@]. But there will be some slack in the chains do to the motor is not running. The tentioners work off of oil pressure and the relax a bit when the engine is off.
#25
Crap.... Well I can walk you through the visual.. I can pick up the chain about 1" off of the cam, there is so much slack that I could have removed it without releasing the tensioners...
BTW- Thanks for all your posts regarding this, and for your service to our country.. I assume the government computer is military...
#26
also for future reference, notice how in the spun bearing vid the cam is about 10-15 ft from the car, HOOD closed, and the sound is very audible. Timing chain slap will not be as audible, as you have your hood open and are 2 ft from the engine and the noise is just as or maybe even less audible.
#27
ORIGINAL: 2000GTFOOL
Yes military computer
#28
I'm not an expert but when I put my chains on and the tentioners and everything there was only about a quarter inch if that of slack and now I have about an inch also. I almost guartee it's not supposed to be like that. Like I said before, I had the same slapping noise and just thought it was the chain moving against my guides that are old and the plastic was worn. Now my car won't start. I am going to have it towed to a mechanic who is very good at working on Mustangs and I'll see what he says.
About the spun bearing, my buddy has the same year GT as me and he had a very small knocking/ tapping noise coming from his motor. He had it looked at and it was a spun bearing. He just had his motor rebuilt. We both had two different noises coming from two different spots on the motor. I hope my experiences help.
#29
I am going to try and get the cover off tomorrow. I have the parts so once it is apart I should be golden. (if it is the tensioners) I will take pictures and make a write-up diary regarding the diagnosis and eventually the fix of the problem.. I can't believe I let it sit for almost a year..
