Lowering springs?
Old 11-04-2007, 12:00 AM
02gtvertible
02gtvertible's Avatar
Default Lowering springs?
Anyone have any before and after shots of their cars with lowering springs? like 1 1/2 or 2 inch drops?
02gtvertible is offline
Old 11-05-2007, 12:28 AM
96beauty
96beauty's Avatar
Default RE: Lowering springs?
i have pictures if you can explain to me how to get them on
96beauty is offline
Old 11-05-2007, 06:58 AM
2000GTFOOL
2000GTFOOL's Avatar
There is a huge thread on here with before and after shot along with the brand of spring used..
Also here is my simplified how to..
https://mustangforums.com/m_2736756/tm.htm
The search function on this forum reaps many awesome results..
2000GTFOOL is offline
Old 11-05-2007, 08:11 AM
trickdriller
trickdriller's Avatar
ORIGINAL: 2000GTFOOL
Yeah, I read that and was all motivated about doing my front suspension this weekend. Guess what? It STILL took me six hours to get it done!!! That friggen caliper kept getting in my way!!! If I had to suggest something, I'd say remove the shock from the bottom so you can prop the caliper up in the wheelwell agains it. I did that on the second side and the job was MUCH easier. Your directions did help, but the job is still far from easy.
trickdriller is offline
Old 11-05-2007, 10:58 AM
2000GTFOOL
2000GTFOOL's Avatar
HUH.. That's crazy.. I think clearance is the biggest contributor.. The higher off the gound the car is the further the a-arm will drop. The only reason I dropped the shock from the top was because I was installing the UPR camber adjusters (FYI).
Old 11-05-2007, 11:03 AM
Car_Ramrod
Car_Ramrod's Avatar
maybe these will help...these are with Eibach Pro Kit...claim a 1.5" drop. not quite the same angle in the pictures. but you can get the idea at least. worth the money to drop it!
Car_Ramrod is offline
Old 11-05-2007, 11:05 AM
Car_Ramrod
Car_Ramrod's Avatar
hmmm its been a while since ive posted...hopefully this time it will work. sorry for the double post!
[IMG]local://upfiles/13981/4E0D9FFDCFD94C3E8B7C645612806AE5.jpg[/IMG]
[IMG]local://upfiles/13981/3C0A69FC31764A50B0FA8874106ECC93.jpg[/IMG]
Old 11-05-2007, 11:11 AM
Eagle2000GT
Eagle2000GT's Avatar
Does anyone have any measurements from the ground? I bought a used GT and have not yet started suspension work. How far off the ground is a stock GT? How far off the ground after it's lowered?
Eagle2000GT is offline
Old 11-05-2007, 01:47 PM
jojo2003
jojo2003's Avatar
I am not for sur eon whether or not mine is lowered, but mine is 2 foot 9 inches from the ground to the bottom of the fender above the tire.
jojo2003 is offline
Old 11-05-2007, 03:16 PM
nathansee3
nathansee3's Avatar
BEFORE:
AFTER:
H&R SS Springs from: americanmuscle.com 1.75" drop
KYB AGX Struts/Shocks from: eBay.com
Maximum Motorsports Caster Camber Plates from: stangsuspension.com
nathansee3 is offline
Quick Reply: Lowering springs?
