FOR REAL 4v head swap ASAP
#21
RE: FOR REAL 4v head swap ASAP
ORIGINAL: Ehmark
The 96-98 b series heads flow GREAT they have a very high peak flow. Butlack down low. At .500 lift B series flow 231Cfm 99-01 heads flow 225 cfm at the same lift and 03-04 cobra heads flow 233 at that lift.
Ford DID do their research on this one, believe it or not, guys.
The heads are a great idea. If you're getting a built short block... + 4v heads... an EASY 600-700 hp could be coming your way with some boost
#23
ORIGINAL: banned
i am definitly buying 4vheads, im just trying to figure out if b heads are a good starting point
#24
yeah im just trying to make sure the cost is ok... i stil have to buy an intake, valve cover and TB to fit... the price is 340 for the heads and timing equipement assembled with cams - i think its a good deal
#25
ORIGINAL: banned
#29
alrighty gotta get some real facts in here.. first of all, 96-98 4v heads flow basically just as well as 99-04 4v heads, they all flow within only about 20+/- cfm of each other. IMRCs don't do much at all, the torque loss with getting deletes is veryy minimal, too small of a change to even feel. as for the swap, i think it'd just turn out to be expensive cause you always end up having to buy odds and ends **** for something like that
#30
so you recommend what?... i have also found a complete motor for a pretty good price, the imrc delete is not a big deal correct? (it seems simple enough)... the only thing is this, i am not going to use the short block of a cobra motor if i buy one, im just buying a pre-assembled short block and swapping all of this 4v stuff on to that
