I Have the T-45 Blues! Help Me!
Old 11-05-2007, 01:35 PM
4.6LPoppy
4.6LPoppy's Avatar
Default I Have the T-45 Blues! Help Me!
I got my 2000 GT 2v rebuilt and back on the strip last weekend. I got a good dynotune and the engine is great. It's s/c'd, forged, big fuel, big spark, etc., etc. Produced 492 rwhp (on Mustang Chassis dyno....not a DynoJet!). I ran a 12.09 at 115. Problem: I think my T-45 gave up on the last run. It drives OK, but sings really loud in 1st and 2nd. It also makes a "zipping" sound in between gears when shifting slowly. Seems to drive fine though.
QUESTION: I've read that T-45s are not strong enough for built engines. Is that right? What next?? I want something that I don't have to change clutches, shorten driveshaft, change mount position, etc. for. TKO500/600? T3650? Or I can rebuild it for a $267 kit. What? Thanks.
4.6LPoppy is offline
Old 11-05-2007, 02:27 PM
Mark99GT
Mark99GT's Avatar
Default RE: I Have the T-45 Blues! Help Me!
A T-45 wont last too long with that kind of power at a drag strip. If you have the cash a TKO500 would be nice. You can get either the 10 or 26 spline input shaft depending on your clutch (stock T-45 is 10 but 26 would be a nice upgrade). A TR3650 would be a waste...
Mark99GT is offline
Old 11-05-2007, 02:30 PM
wwmost
wwmost's Avatar
dont rebuild it... your just going to have to rebuild it again in a ltitle. ask 2000gt4.6
wwmost is offline
Old 11-05-2007, 03:59 PM
4.6LPoppy
4.6LPoppy's Avatar
ORIGINAL: Mark99GT
What adaptors will I need to make a TKO500 work with the T-45 bellhousing, etc. or will it? Anyone reading this using a TKO500? I like what I read. They are good for 500 lbs of torque.
Old 11-05-2007, 04:02 PM
4.6LPoppy
4.6LPoppy's Avatar
ORIGINAL: Mark99GT
I have a Centerforce Dual Friction clutch. Output shaft is 31 spline, right?
Old 11-05-2007, 04:37 PM
Mark99GT
Mark99GT's Avatar
ORIGINAL: 4.6LPoppy
ORIGINAL: Mark99GT
The bellhousing is integral to the T-45, its all one piece. You'd have to get a bellhousing along with the TKO transmission, which can usually be ordered all as one package deal (it also comes with a short throw). Thats the good part though, you'll be able to remove the transmission from the bellhousing should it ever need work. Especially nice if you have longtubes. The centerforce you have is a 10.5" 10 spline clutch. Just order the TKO with a 10 spline input shaft (though the 26 spline is stronger). 2000GT4.6 has a TKO500, you can ask him about it too...
Mark99GT is offline
Old 11-05-2007, 04:45 PM
4.6LPoppy
4.6LPoppy's Avatar
ORIGINAL: Mark99GT
ORIGINAL: 4.6LPoppy
ORIGINAL: Mark99GT
Good info. Thanks. This seems the way to go. Are there other trannys that 4.6 guys are using with success for built engines or is the TKO about the only choice?
Old 11-05-2007, 04:50 PM
Mark99GT
Mark99GT's Avatar
The T-56 but you'll need a new driveshaft etc...
Mark99GT is offline
Old 11-05-2007, 05:50 PM
lizzyfan
Underboss
lizzyfan's Avatar
TKO 500, and get it with the 26 spline shaft. DO NOT waste your money on rebuilding a T-45.
lizzyfan is offline
Old 11-05-2007, 05:51 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: Mark99GT
T-56 is not worth the extra money, stick with the TKO 500/600
lizzyfan is offline
Quick Reply: I Have the T-45 Blues! Help Me!
