weight on diff.?
Old Nov 14, 2007 | 07:49 PM
MustangMan00's Avatar
MustangMan00
Default weight on diff.?
hey i heard through a friend that this is just a unecessary weight on the diff. can i take it off and have no problems?
[IMG]local://upfiles/33307/87D072D7DFD64A25AF97160848206964.jpg[/IMG]
Old Nov 14, 2007 | 08:06 PM
Emanpimpster's Avatar
Emanpimpster
Default RE: weight on diff.?
looks important to me lol
Old Nov 14, 2007 | 08:13 PM
MustangMan00
well this guy my friend knows is all about weight loss and he took it off his 97 said it was just a weight block
Old Nov 14, 2007 | 09:49 PM
MustangMan00
anyone i plan on takin it off tomorrow if its useless weight, but it has to be there for a reason....
Old Nov 14, 2007 | 09:51 PM
sstang's Avatar
sstang
Even if it was dead weight, it couldn't be too much and I would leave it since it's in the back.
Old Nov 14, 2007 | 09:52 PM
oxfordgt's Avatar
oxfordgt
Its there to control vibration in the rear end. I wouldnt remove it if I were you unless you have an aluminum driveshaft.
Old Nov 15, 2007 | 03:28 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
It (the "dogbone") weighs 8 and a bit pounds, mine has been off since I installed the 3.73 gears in March--20k miles or so with no ill effects of any kind. Its purpose is 100% NVH reduction, although I can't say I've noticed any increased levels of any of the three.[/align][/align]You'll need a couple of shorter bolts (3/8-16 x 2-1/2" if memory serves) to remount the axle snubber, which is important, and is held on by the same bolts as the dogbone.[/align]
Old Nov 15, 2007 | 06:58 AM
BraMas's Avatar
BraMas
Defiantly for NVH (Noise,Vibration,Harshness). You guys are aware that removing an 8 lb weight in a street car will yield you nothing. Plus that thing is right where you want the weight in the rear and in the middle[&:]
Old Nov 15, 2007 | 08:27 AM
MrChubs1's Avatar
MrChubs1
ORIGINAL: BraMas
Differently for NVH (Noise,Vibration,Harshness). You guys are aware that removing an 8 lb weight in a street car will yield you nothing. Plus that thing is right where you want the weight in the rear and in the middle[&:]
If you're trying to lighten your car, 8 lbs certainly isn't nothing. Sure, you'd like to remove that weight from the top, front of the car, but weight is weight.
Old Nov 15, 2007 | 10:06 AM
TurtlePimp's Avatar
TurtlePimp
I just wanted to add that as a 20 year mechanic and a shop owner, no Mustang that gets gears or any other rear end service leaves with the counter weight. It is " **** on a bull". Interesting to look at, but worthless.
