weight on diff.?
Old Nov 15, 2007 | 10:09 AM
venom3469's Avatar
venom3469
Default RE: weight on diff.?
That would be stupid for every 10pounds is 1hp. (from what i hear) This is only 8 pounds u say then u wouldnt even gain 1hp out of this. So no dont that would be pointless
Old Nov 15, 2007 | 03:37 PM
oxfordgt's Avatar
oxfordgt
You don't gain any hp from removing weight. For every 226 lbs removed = .1 off your time in the 1/4 mile.
Old Nov 15, 2007 | 04:27 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: oxfordgt
[/align][/align]You could remove 1000 pounds and not gain any horsepower. As for removing 8 lbs. having no effect--nonsense... It may be a very small effect and negligible effect, however it has to have some effect. It is also unsprung weight. Certainly not a giant component of the total unsprung weight of a Ford 8.8" rear-end, nonetheless reducing unsprung weight is always good. [/align][/align]I agree that removing it will make make no discernible difference in anything, however it also does no harm; much like removing the air silencer or slapping in a K&N drop-in filter. There's a whole lot of crap people do modding their cars that provides no measurable performance gain by itself, or for that matter ever--nonetheless we all do it, have fun doing it, and I plan to keep on doing it 'til the day I drop...[/align][/align]
Old Nov 15, 2007 | 05:13 PM
venom3469's Avatar
venom3469
ORIGINAL: cliffyk
ORIGINAL: oxfordgt
[/align] [/align]You could remove 1000 pounds and not gain any horsepower. As for removing 8 lbs. having no effect--nonsense... It may be a very small effect and negligible effect, however it has to have some effect. It is also unsprung weight. Certainly not a giant component of the total unsprung weight of a Ford 8.8" rear-end, nonetheless reducing unsprung weight is always good. [/align] [/align]I agree that removing it will make make no discernible difference in anything, however it also does no harm; much like removing the air silencer or slapping in a K&N drop-in filter. There's a whole lot of crap people do modding their cars that provides no measurable performance gain by itself, or for that matter ever--nonetheless we all do it, have fun doing it, and I plan to keep on doing it 'til the day I drop...[/align] [/align]
Have you ever heard of power to weight ratio. You remove a 1000 pounds i assure you. You will be gaining hp. Not of of 8 pounds but a 1000...yeah you will
Old Nov 15, 2007 | 05:29 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: venom3469
ORIGINAL: cliffyk
ORIGINAL: oxfordgt
[/align][/align]NO, you will not gain ANY horsepower by removing weight--you will indeed be able to accelerate faster because of improving the power-to-weight ratio, however your engine will not be producing any more power, it will simply have lessmass toaccelerate with the exact same amount of power (actually torque) it had before...[/align][/align]The resulting improved acceleration might well be interpreted bysomeone with no engineering expertise as an apparent increase in power, however I assure you reducing vehicle weight will have absolutely no effect onitsengine's output.[/align][/align][/align]
Old Nov 15, 2007 | 05:30 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
deleted---double posting for some reason???[/align]
Old Nov 15, 2007 | 05:51 PM
racer02GTstang's Avatar
racer02GTstang
im keepin mine... i need all the weight on the rear end that i can get.
Old Nov 15, 2007 | 06:36 PM
venom3469's Avatar
venom3469
Well I figured that was understood but I thought u were saying ur times would not improve...
Old Nov 15, 2007 | 06:48 PM
oxfordgt's Avatar
oxfordgt
ORIGINAL: venom3469
Do you know what it takes to remove 226 lbs from a street car. It would be easier and cheaper to add horsepower then to try to take weight out of a street car.
Old Nov 15, 2007 | 07:16 PM
tim2002gt's Avatar
tim2002gt
I've always heard that 100 lbs. of unsprung weight (seats, etc.) will drop approximately 1/10 of a second from 1/4 mile times. And 10 lbs. of sprung weight (driveshaft, lightweight wheels and tires, etc.) will also drop 1/10 of a second.
I may have the terms sprung and unsprung switched, i'm not sure, that's what the examples are for!
