Drilling temp sensor on manifold
Old Mar 6, 2005 | 10:12 PM
Gaspi101's Avatar
Gaspi101
Default Drilling temp sensor on manifold
If one is installing a PI intake manifold on a NPI block and heads, I need to drill a hole in the manifold to relocate the temperature sensor. Any idea how and where I should do this? I've never done anything else like this, so the more specific the better. Thanks for any help!
Old Mar 7, 2005 | 12:13 PM
stonemonk9's Avatar
stonemonk9
Default RE: Drilling temp sensor on manifold
I put a T fittin into the port for the sensors and ran them both off that.
Old Mar 7, 2005 | 05:24 PM
Gaspi101's Avatar
Gaspi101
A T finning, huh? I have no idea how that would work, but I'll give it a shot. I really don't see how anyone is supposed to drill anything in this thing. Thanks!
Old Mar 7, 2005 | 07:09 PM
USAMuscle's Avatar
USAMuscle
The T-fitting is not a good idea. Many people who have done that are having problems with their car overheating because the CPU is not getting the correct temp signal. Your best options are to get an intake with an aluminum crossover because they have a boss where you can drill and tap a hole for the temp sensor, or you can relocate it to the side of the block. Either of these options will work fine and you shouldn't run into any problems.
Old Mar 8, 2005 | 01:58 AM
stonemonk9's Avatar
stonemonk9
Ya, def avoid the t fitting if you can cuz hes right my card would overheat all the time untill i made my own fan switch so wen ever im jus doin stop go or sittin at a light i flip it, kinda a pain in the ***, but im usta it.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
