New Mac Intake...but Service Engine Soon...Please Help
Hey guys i know you know more than me in this situation...I installed a brand new mac air intake with bigger MAF...there is a whole at the bottom of the pipe that comes out of the throttle body..what is that for? is it supposed to be open? Why did the Service Engine Soon light come on as soon as i Turned it on?
Thanks for the help
Thanks for the help
RE: New Mac Intake...but Service Engine Soon...Please Help
ORIGINAL: laserredgt
Thanks for the help
Thanks for the help
The 99-01 1/2 cars have a seperate IAT sensor that is around that location. The 01 1/2+ cars have a integrated IAT.
alright thanks...yeah its an 02 so it probably has that then...umm so should that hole be covered or open? b/c when i turned it on the first time it didnt light up the sign..but then i remembere about it and turned the car off and when i covered it and turned the car on the light went on as well...
it usually takes a minute after theres a problem for a CEL to come on...it usually wont happen immiedately after something goes bad (my mil eliminators disconnected themselves while i was driving and i heard it rubbing the ground. i couldnt get it on a lift to fix it till the next day and the CEL didnt come on for about 20+ miles of driving.
the CAI i bought had a hole too and its for that sensor thing that we dont have. i bought a bolt from o-reillys and shoved it in there and it works fine. it needs to be covered otherwise your car will spaz out. your getting air into your intake that isnt bieng read by the MAF. get a bolt or something, stick it in there (make sure its a tight fit obviously) then disconnect your battery for a couple minutes to clear the code and you should be good to go. if not then clean your MAF
it came with it...lol you know ebay....but yeah anyways about the hole situation i will have to find a plug for it...thanks for all your info guys...preciate' it
TfcCDR
09-14-2015 12:08 PM
