Anyone with a wideband O2 on a NA vehicle?
RE: Anyone with a wideband O2 on a NA vehicle?
the truth is most people go pay other people to dyno tune their cars. most people dont understand fuel or timing maps, etc. and with n/a most people, i said most before i get jumped on, are happy with a mail order tune.
If you can get the wiring diagram for the knock sensor, then I could probably cook something up that would work. I would guess a simple logic switch and a relay from Radio Shack would do the trick, but I would need to know the output from the sensor.
Here is the information that I would need:
1. Output voltage during both knock and no knock conditions (I would guess 5V / 0V)
2. Sensor power requirements (Probably 12V)
3. Type of light you will be using (LED, would be easier to work with)
PM me if you want help. I do not know if the drilled holes are really for knock sensors, but if they are then this will be a simple project.
ORIGINAL: sweet99
OK. I need 2 hearing aids so I cannot hear knock. I leaned my AFR with the SCT 4% at WOT, what is my AFR or should I not be concerned? I backed off the timing 6* above 4000rpm's but I can read that on the tuner.
My last car was a 500+whp AWD Talon running 30psi on a 65lb./min. Holset turbo. I had a device that read knock and of course a wideband.
I have spent around $300. on mail order tunes. I called DezRacing and they want $350.-$400. for a dyno tune. 4-5 hours each way plus an overnight stay.
I am not argueing but presenting the facts. As I said I also want to monitor knock and know it can be done as the 2V heads are drilled and tapped for the sensors. What I don't know yet is how to translate the signal to an electrical signal so a light(s) will blink with knock in the cabin.
Besides that I live in central,NY and I am already bored and the car just went into storage a week ago though my garage can be heated. A lift would be nice too!
Seriously how do you NA guys who are serious tune your cars? I have not posted asking if there is a shop nearby that is familiar with Fords and the SCT software so maybe this is moot but it is something to look into.
Headers are a bigger waste but for some reason that fact is doubted and they are heavily touted. Even Dez said to skip headers with the mods I have. Well I will stay on topic.
I think I will look into a ram air cold air system and see if that adds some power. THX!
There is little reason to change your tune every time you put a small part in on a n/a car. If your really that worried about it, save for your upgrades and do large amounts of them at once (full exhaust isntead of a catback, then a midpipe, then LTs etc etc). Regardless, adding a catback on a n/a car isn't going to throw the tune off that bad, hell I was running a stock tune on a full boltons car and it was fairly close (256 WHP, typical is 260-265).
LTs are NOT a waste of money. On a properly tuned car they can pick up 10-15 WHP, which is alot for a bolton on this car, far more than any other bolton will add. As you add more mods down the road they will make more and more power.
Dyno Kings
03-07-2014 10:44 AM
Dyno Kings
03-05-2014 11:41 PM
Dyno Kings
02-25-2014 05:52 PM
Dyno Kings
02-25-2014 05:15 PM
Dyno Kings
4 Cylinder NA and Turbo
02-25-2014 05:13 PM
