Installing My Own Gears...
Old Mar 7, 2005 | 11:56 PM
kubball2005's Avatar
kubball2005
Default Installing My Own Gears...
Ok fellas, I could use a little advice with a gear install. My uncle and I are putting in my 4.10s and he is suggesting some parts I should put in along with the gears and I wanted to make sure they were totally needed. I am getting a diablo tuner for speedo recalc. and I planned on replacing the bearings already. However, he is saying something about putting in new Races (no idea what they are), Crush Ring, using a Shim Assortment, and also putting in axle seals (something to do with fluid possibly leaking). Is all this stuff really needed because I don't wanna spend money on parts I won't need. Thanks for any input guys.
Old Mar 8, 2005 | 12:59 AM
yellowstang98's Avatar
yellowstang98
Default RE: Installing My Own Gears...
if hes a mechanic the first rule is listen to him they have gear installation kits, which comes with shims and crush ring-prolly want to look into that, im sure its what he is talking about. i think they run about 80 bucks
Old Mar 8, 2005 | 10:40 AM
kubball2005
Ok, thanks for the advice. I'll look into one of those kits. He's not a mechanic but knows a hell of a lot.
Old Mar 8, 2005 | 09:48 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
If you look at another post about gears in here, i listed everything you will need and everything i would suggest.
Old Mar 8, 2005 | 09:59 PM
neogenic83's Avatar
neogenic83
make sure u get the back spacing right or u are gonna be buying new gears soon not to mention the terrible sound.
Old Mar 9, 2005 | 01:03 AM
kubball2005
ORIGINAL: neogenic83
I don't think I'll have a problem with it. My uncle has changed out and tweaked the gears on his TA multiple times and he hasn't had any problems. BTW, I picked up an installation kit today for 40 bucks at a mustang shop so now all I need to get are the bearings. Anyone know where I can get some for a good price?
Old Mar 9, 2005 | 05:49 PM
kubball2005
I found these bearings on ebay and was wondering if they were what I needed for gear install. I'm not sure if they're the right thing I need or not.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Mar 9, 2005 | 09:51 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Hey bro, sorry it took a lil while to post. But i have been busy alot lately. So ok.... Those bearing you found are for the axle seals and axle bearings. MAKE sure you have a slide hammer with a axle bearing removing tool screwed on the end of it. IF you plan on replacing the bearings. Being you have a 99, its not even worth the time to replace them. They wont be bad for a while. as for the seals ( axle seals).. Some people remove the axles when doing gears... ME NOPE! I just plop the c-clips out of the way and slide them out just enough to yank the carrier out. I found the post and its at the top of the 4.6 forums.
Old Mar 10, 2005 | 12:33 AM
stonemonk9's Avatar
stonemonk9
lol, love the quote casper!
Old Mar 10, 2005 | 01:08 AM
kubball2005
ORIGINAL: Casper98GT
Thanks for the post casper, but you're saying I really don't need to replace the bearings? I've heard from lots of guys that if you have high mileage (90 k on mine) that you should replace them.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
