First off it's a 4v. 3v is the new body style GT. If you want to put in a 4v its an easy swap. If you want ot put in a 3v then you've got your work cut out for you.
SO i need the engine, and a reflash? nothing else? Would a t-45 handle it ok? What is the max power a T-45 can safety handle?
Wouls i need a bigger fuel pump??? anything besides a reflash?
last time i checked i believe you need a the cobra radiator, different K member bracket or new k member, not sure about motor mounts? i might be wrong though?
