trans oil???
RE: trans oil???
yes synthetics are available and are recommended.
when i changed mine after some research i put in 3.2quarts (3L) of mobil 1 synthetic ATF. there is a big debate on what and how much to put in, whats recommended in the manual is not the correct they later found out.
RE: trans oil???
3.17 quarts (3.0 liters) of Dexron III/Mercon is specified by Tremec for the TR3650. Synthetics are bad for these trannies, some addatives in a synthetic will eat away atcertain internal parts.
RE: trans oil???
ORIGINAL: OzzDOA
Syn ftw!
RE: trans oil???
Right out of the TR3650 service manual:
"TREMEC engineers have recommended Texaco-Havoline Dexron III/Mercon Non-Synthetic ATF. The most recent Ford owner's manuals specify 3.17 quarts of a non-synthetic Mercon ATF. Synthetic fluids willcause prematurewear of the synchronizer materials."
RE: trans oil???
That Mobil 1 stuff is thefluid that Ford put in from the factory that contributed to all the shifting problems that people were/are having with the 3650. I put Valvoline Dexron III/Mercon in my trans and the differance was considerable. The trans shifted much smoother and cold weather shifting was 1000% better.
