Need help!
Old Nov 26, 2007 | 07:38 PM
BRYAN03GT's Avatar
BRYAN03GT
Default Need help!
Hey guys, i just recently installed an o/r x on my gt and now my cars throwing out a 02 sensor code(expected) anda p1151 code or something like that... The guy at autozone said it was a delarship code and all he could tell me was that it said some about the a/f management... So basically my question is could my new o/r x be messing up my engine and cause a problem? Yes i know, kinda a noob question! Sorry!
Old Nov 26, 2007 | 08:58 PM
oxfordgt's Avatar
oxfordgt
Default RE: Need help!
More than likely a vacum leak or bad EGR
Old Nov 26, 2007 | 10:33 PM
BRYAN03GT's Avatar
BRYAN03GT
So what would be the simplest way of findind the leak? And egr?
Old Nov 26, 2007 | 10:47 PM
99black5spd's Avatar
99black5spd
i dont think its the egr cuz when i put on my prochamber from mac it tripped the same codes and i ordered the mil emliminators and it turned the check engine light off....im not sure if it will work for you so dont go right out and buy them...do a lil research on them first and see what it says..
Old Nov 26, 2007 | 10:52 PM
BRYAN03GT's Avatar
BRYAN03GT
Well i really dont want to get the mil elims. untill after i get this fixed, but i hate the idea of my car running to rich or lean!
Old Nov 26, 2007 | 10:54 PM
99black5spd
understandable....best thing to do in my opinion would be to bring it to a local shop and have them look at it...you dont want to be replacing things that dont need it ya know...or hopefully someone will be able to help you on here
Old Nov 26, 2007 | 11:05 PM
BRYAN03GT's Avatar
BRYAN03GT
Yea im hoping that someone can help me out! The shop i trust with my car is about 20 minutes away and i'd rather take a few cracks at fixing the car, before i take it to them!
Old Nov 26, 2007 | 11:20 PM
MU71L4710N's Avatar
MU71L4710N
allright well theres your problem. you HAVE to get mil eliminators with an off road pipe (it probably even tells you on the description on the webpage you bought it from). you can use a handheld tuner to turn the rear o2 sensors off also (if you got one)but thats why your cars screwed up. if you know how to solder theres a post around here to buy some resistors for 5 bucks and solder them in yourself. i dont know how well this works or the longevity of it but with an OR pipe (or even some high flow cats) you gotta have elims because your rear 02 sensors are there to detect if your cats are working properly and guess what happens if you dont have cats? your car thinks they arent working so it starts screwing with your car.
oh once you put them in you gotta disconnect your battery for a couple minutes to clear the code then it should be fine
Old Nov 26, 2007 | 11:23 PM
BRYAN03GT's Avatar
BRYAN03GT
Im anything but cheap when it comes to my stang! I just rather take a crack at problem before i drive across town for a simple10 minute fix(guess)!
