misfire....
misfire....
I have a misfire in cylinder number 6.so ichanged coil packs, ignition wires, spark plugs, and still it continues to misfire, so i checked them all, and they seemed fine, although the ignition wire into cylinder 6 did have some signs of arcing, it was a little white on the tip. anyway... i ran a compression check on the cylinder and that was fine, everything seems ok yet it still misfires in the cylinder. what else could it be or what could i check?
no vacuum leaks or other leaks of any sort either.
Thanks
Lewis
96GT 5 Speed
Thanks
Lewis
96GT 5 Speed
RE: misfire....
ok thanks. could it be fuel pump? i think my fuel pump might need replaced...
Isnt fuel injector, i jjust switched 5th and 6th injectors around incase the misfire moved to the 5th cylinder, but its still 6. what do you guys think??
thanks guys
thanks guys
RE: misfire....
fuel pump would be a total engine misfire or a no run condition. if you switched the injector and still no change, the injector circuit itself could be bad. take it somewhere to get it plugged in and the scanner will be able to tell you if you have an injector ckt fault. if not it could be a coolant leak into the cylinder via headgasket.
RE: misfire....
ok thanks.
If it was to be a coolant leak into cylinder via the headgasket, that is gonna be a bitch to replace right? or what do you think?
my coolant light is also on, and im definately leeking coolant, so does that make you think more that this is the problem?
thanks man
Lewis
thanks man
Lewis
RE: misfire....
ORIGINAL: lewistk
If it's not this or your fuel, check out your cam and crank sensor.
RE: misfire....
It was already misfiring... then i started changing things out.
What sort of tools am I gonna need to get intochanging the headgasket? Im pretty sure thats the problem, im changing my fuel pump too as there is a lot of hesitation/stumbling during acceleration and i think fuel pump is problem.
Thanks
Thanks
