Under Pulley?
#21
RE: Under Pulley?
ORIGINAL: snlpa
I am not sure if slowing your water pump and alternater down is a good Idea for everyday drivers. Is it worth 8hp? I am not sold yet...?
#23
RE: Under Pulley?
ORIGINAL: snlpa
Ok, here it is folks. UD pulleys slow down your accessories by only 25%,thus your water pump and Alt. will spin a tad bit slower in turn allowing the engine to rev faster. I live in Texas and my car has seen temps of 110 degrees and never once has my car come close to over heating. I also use my lights in the day along with the radio and A/C and a cell charger and sometimes a laptop charger and not once have I experienced a voltage problem. Im convinced that Steeda UD pulleys are more than completly SAFE!
Any more questions?
#24
RE: Under Pulley?
ORIGINAL: propellerhead
Same here. I'm not sold on the "under pulley" thing. I won't argue there are gains, but there are too many issues at idle speeds. A slower water pump reduces cooling efficiency. A slower power steering makes it harder to steer. A slower alternator means less charging. Then you have two sides to the piggy-back or not issue. Some say do not remove the stock harmonic balancer. Aftermarket ones aren't made for daily drivers. Some say replace them. Dunno. Both sides claim seeing motors blow up due to harmonic vibrations. Do I want to deal with all these issues for 6-8 hp? No.
ORIGINAL: snlpa
WAY TOO MUCH CONTEMPLATION HERE!!! Never have I read such stupidity EVER! You will not blow an engine due to crank vibration because I drove to Killeen From South Padre Island (800 miles) in a '94 Cobra with a bad balancer seal making the whole car shake. It didnt blow and the car didnt even have UD pulleys! Like I said... ive had mine for over a year and never had a problem. Its stories like this that scare people out of modding their cars because ignorant people open their mouths and speak without experience!
#27
RE: Under Pulley?
ORIGINAL: jdaniel
#28
RE: Under Pulley?
I have no clue when the last time they pulled one out to test it. LOL Im sure the crank would hold up under a lot heavier conditions though. Hell, it will hold what.... 1000fwhp? My question is why do they match such strong cranks to such weak connecting rods and so on?
#29
RE: Under Pulley?
There's vibration and there's harmonic vibration. http://www.atiperformanceproducts.co...mper_dinan.htm
Stupidity? You decide. It might apply to you. It might not.
I chose not to take my chances for the small gain the pulleys would give.
romancer: Isn't the power steering pump driven off the main pulley? If so, then a smaller main pulley will slow down the power steering pump too, unless you change the power steering pulley to compensate.
#30
RE: Under Pulley?
