Springs
Springs
Im looking to get some lowering springs. Probably the Ford Racing ones, because I dont have a huge budget for it. Are these hard to install yourself, or should I have a shop do it? and if a s hop does do it how much money am i looking at paying?
thanks
nick
thanks
nick
RE: Springs
It really depends on how much you know about working on cars... Its not hard at all if you have any clue what youre doing. Just look at a write up on installing springs and if you dont understand what its talking about then you probably need to have a shop do it. A shop is gonna be somewhere in the range of 200$ I would suggest doing it yourself if you could.
RE: Springs
Spring installs are really easy. If you follow the instructions its hard to mess up... so long as you bolt everything back into the same location and don't break any bolts etc there really isn't much of a way to screw anything up. Pretty much nothing will go on in the wrong direction etc... the only thing to watch is make sure you check out which way the end ofthe spring is pointing and put the new ones the same way.
