HALO HEADLIGHTS HELP ASAP!!!!!!!!!
#31
RE: HALO HEADLIGHTS HELP ASAP!!!!!!!!!
I dont see what the Big Deal with Halo's are???? Damn Everything that someone on here doesnt like is RICE!!!!!! Sooo watchout you have to Keep your stang looking like EVERY OTHER stang to not be Rice!!!!!!
http://customerpics.americanmuscle.c...013&id=814
Stang Pic 2 is UGLY!!!(lights are best part though )
#32
ORIGINAL: Kmoran81
Let him do what he wants, its not your car, and he was just asking for some help. Isnt that what this site is about? I may be new to this forum, but I really cant believe the immaturity of some people. Just my $0.02
-K
-K
#33
^+1, thats the only thing you will learn about these forums. If you dont have saleen/cobra/bullitt rims and a cobra hood no body will like your car because it doesn't look like every other stang on the face of the planet. Its your stang, mod it up how you want. Just dont go overboard. Its funny how the guys ripping him have nearly stock mustangs. I run halos and really like the look of them on my car...dont see what the problem is.
#35
Hey I justed installed the same set of lights on my car. There are 3 wires on the car the middle is the hot one for the parking lamps. Take the two red wires from one headlight splice it into the middle wire for the parking lamp. Then take the two grounds from the headlight and i ground them right behind the headlamp there are two bolts for the support. Which i grounded them two. When you turn on the parking lamps the halo lights come on.And make sure u seal the headlights real good first time my got moisture in them. Went back and sealed them, now its all good.
#36
i got these lights 2 just i hooked the halos up 2 a switch so i can choose when to have them on and off..i had a body shop put my lights on since i couldnt get them 2 fit right but when they hooked up the halos one wasnt hooked up right so only 3 came on so i cut the wires and ran all 4 of them 2 a switch inside the car...just thought it might be alittle helpful if neone wants to do it that way
Seanam
10-04-2015 10:15 AM
