Lash Adjusters / Stem Seals
Old Dec 4, 2007 | 09:27 AM
pete1665's Avatar
pete1665
Default Lash Adjusters / Stem Seals
1. Has anybody actually replaced these with the camshafts in place and the engine in the car. I know that it CAN be done, but i'm wondering if it is a PITA doing it this way? I'd prefer to not remove the cams if i don't have to.
2 . Wheres a good place to get new lash adjusters and valve stem seals?? I've done a little searching but only turned up results for the 5.0.
Thanks guys.
Old Dec 4, 2007 | 09:33 AM
GolfmanSpeck's Avatar
GolfmanSpeck
Default RE: Lash Adjusters / Stem Seals
I don't know about removing them without removing the cams, but I do know that you can get them from MMR.
Old Dec 4, 2007 | 09:42 AM
pete1665's Avatar
pete1665
thanks golfman. do they have a website?
Old Dec 4, 2007 | 03:58 PM
oxfordgt's Avatar
oxfordgt
www.modularmustangracing.com
You can remove the lash adjusters without removing the cams but you need the special ford spring compressor to do it.
Old Dec 4, 2007 | 04:04 PM
4.6LPoppy's Avatar
4.6LPoppy
Yes, you can put the lash adjusters in with the cams in. If you have the "ladders" across the cams, you will have to loosen them a little, especially the one at the back of the head (firewall) so you can tilt the cam up a little for the front lash adjusters to slip under the bridge. Don't let the cam gear slip a link. You just need to roll the cam gear (crankshaft if the head is on the engine) so that the lobe is away from the lash adjuster before it can slip under it. It will work, I just didthis recently.
Old Dec 4, 2007 | 04:13 PM
oxfordgt's Avatar
oxfordgt
That really isn't the proper way to do it. Use this tool http://www.toolrage.com/prodView.asp?idproduct=4464. That compresses the spring so you can pull the cam follower out and then remove the lash adjuster. Just be carefull with this tool if you force to much and don't pay attention to what your doing you can bend the valve. They do sell a spring stop to go with this tool that will prevent that but I can't find it.
Old Dec 4, 2007 | 05:10 PM
4.6LPoppy's Avatar
4.6LPoppy
ORIGINAL: oxfordgt
Sorry. I was thinking about cam followers, not the lash adjusters. Oxfordgt sets me straight again. (But you CAN put in the cam followers with the cam in place!)
Old Dec 4, 2007 | 05:18 PM
oxfordgt's Avatar
oxfordgt
ORIGINAL: 4.6LPoppy
ORIGINAL: oxfordgt
Yeah thats why you use this tool. The cam has to be bolted down inorder to use the tool.
Old Dec 4, 2007 | 10:32 PM
pete1665's Avatar
pete1665
after looking into this more i'm starting to wonder if it is worth the labor. I'll be replacing the Timing chain tensioners/guides along with the oil pump soon, but i'm not sure that i want to tear into the top end as well.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
winner99
Sep 30, 2015 07:04 PM
