help.
thanx for the info oxfordgt, do you think it could be caused by my manifold since i didn't replace the gasket. b/c around those two cylinders, i see a some coolent leaking from there.
ORIGINAL: oxfordgt
If you have 2 cylinder right next to each other that are misfiring then you have a blown head gasket. Do a compression check to verify. What 4.6poppy was saying is that the head gasket is blown out between the 2 cylinders and coolant is coming out of the water passage and going into the cylinders.
ORIGINAL: josh.davis
mungodrums
Suspension
Sep 24, 2015 10:12 PM
then if its a blow headgasket you will hear air escaping from the other sparkplug hole.
