IAC
Old Dec 5, 2007 | 04:48 PM
cfrank2's Avatar
cfrank2
Default IAC
what is the idle air control motor, where is it located, and what does it do, i think it is on the idle air control valve?
Old Dec 5, 2007 | 04:52 PM
oxfordgt's Avatar
oxfordgt
Default RE: IAC
The IACis located on the plenum. It is basicly a controlled vacum leak. The IAC motor controls the amount of air that goes through it to let the engine idle at a preset rpm.
Old Dec 5, 2007 | 04:55 PM
incubus1275's Avatar
incubus1275
Default RE: IAC
The idle air control valve provides a path for air to travel when the throttle is closed. During idle when only a very small amount of air is required, this valve provides more accurate control of the air flow than could be achieved by opening the throttle very slightly. It is located on the throttle body.
Old Dec 5, 2007 | 04:59 PM
oxfordgt's Avatar
oxfordgt
Default RE: IAC
ORIGINAL: incubus1275
NOT
Old Dec 5, 2007 | 05:11 PM
incubus1275
Default RE: IAC
yea i couldnt remember if it was mounted behind the throttle plate on the TB or on the plenum. oh well. havent taken that apart for over a year....my bad
ShaneB26154
35
Mar 4, 2021 04:05 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
fdnyems19
Aug 13, 2015 09:36 AM
