am i getting screwed?
my car has been making a clicking noise for some time now. it has been diagnosed as the timing belt chain. Now ive taken it to 3 mechanics one said 600 but i didnt like the guy so i dont want to take it there and the other 2 said 900 and one guy said 1200. I think that is outragous am i wrong? does it really cost this much?
RE: am i getting screwed?
I wouldn't do it for less than $500 and a case of very good English ale...[/align][/align]Off the top of my head it includes (and I'm sure I missed something):[/align]
[ul][*]Pulling the valve covers (and the brake booster to the get the driver's side off);[*]Remove the fan;[*]Remove the drive belt;[*]Move AC. power steering out of the way;[*]Pull the idle pulley assembly;[*]Remove the crank pulley and oil seal;[*]Remove oil pan bolts on the front;[*]Remove thefront cover;[*]Pull coils and plugs;[*]Position to TDC #1;[*]Have or get a camshaft holding tool;[*]Yank and replace the chains;[*]Make sure it's timed right an put it all back together;[/ul]
Wait, $750 and a case of good ale...[/align][/align]
ORIGINAL: cliffyk
[ul][*]Pulling the valve covers (and the brake booster to the get the driver's side off); [*]Remove the fan; [*]Remove the drive belt;[*]Move AC. power steering out of the way;[*]Pull the idle pulley assembly;[*]Remove the crank pulley and oil seal;[*]Remove oil pan bolts on the front;[*]Remove thefront cover;[*]Pull coils and plugs;[*]Position to TDC #1;[*]Have or get a camshaft holding tool;[*]Yank and replace the chains;[*]Make sure it's timed right an put it all back together;[/ul]
You don't have to do all of that stuff.
its not a hard job at all... i'd do it for 200 + parts...
you have to remove valvecovers, coil packs (easier to get the valve covers off that way, intake tube, electric fan, crank pulley, water pump pulley, a/c and power steering, and the timing cover... timing it wouldnt take more than 5-10 minutes and they it starts going back together. the timing cover gasket i would reccomend replacing but the valve cover gaskets are fine how they are, ive reused mine many times.
