Why Can't Mustangs Auto X?
I have shown an interest in Auto X. I have spoken to a lot of auto enthusiasts and they said mustangs are too slow to do it well.
They spewed that we have to much horsepower and not good enough handling. What is it that other cars have, such as MR2s, Miatas, etc., that limits our abillities? Don't they have more horsepower than we do?
I don't get it.
I don't get it.
RE: Why Can't Mustangs Auto X?
MR2, Miata, 944, all those small cars handle like a go cart with quick speed (low weight). Mustangs on the other hand are quick but weigh a lot so it would be hard for them to turn quickly going at a higher rate of speed.
you can get them to handle fairly well in the aftermarket. we actually have the advantage of having enough power to oversteer the car, which is very good on a tight autocross track. so they will do sh*tty from the factory, but with some work they can do well. it wont do as well as a miata, but it will do.
ORIGINAL: mkspeed26
ORIGINAL: blueangelfightr
Exactally. We have oversteer. Oversteer is good on a tight track. Look for a good suspension package and you will be set. As for too much HP, I didn't know there was a such thing.
ORIGINAL: mkspeed26
Eh, that all depends on what you want your car to do. Too much power can hurt you if you break the tires loose coming out of every turn because you'll lose valuable time. Autocross cars are harder to tune than drag cars because it has to be a fine balance between power and weight, and the suspension to keep it on the track. With drag cars more power = better as long as you can stick it to the pavement.
Since its really unlikely that Mustangs are classed with any of those cars, id have to say they autocross fine. Infact now that there is no Z28 they are the perferred cars for ESP in SCCA. Put a mr2 in a race with alot of long striaghts and a mustang will eat it for dinner. Make it really tight and the mr2 will win
As for to much power. Yes you can make to much power in Autox. The 03-04 cobra is a perfect example of it.
I only saw the track for an afternoon. What angle are those corners? I don't think they are 90 degrees like typical streets. I thought if I took them wider I would not have to slow down as much and lose time. You know slow and steady. But then I don't know how much width I have to work with so I don't hit a cone with the rear end of my car if I fishtail.
"break the tires loose"? [&o]
I appreciate your opinions, but this sounds less and less encouraging. Am I wasting my time even getting involved?
I don't get it.
I don't get it.
