Where's the 93???
Where's the 93???
I am getting a predator tuner in the mail in a couple of days and I'll be playing around with the timing which means I'll need higher octane fuel. I'm planning on setting the timing to 14 degrees and I've been told I need 93 octane. The problem is, the past couple times I filled up at different gas stations I've only seen 91. For the guys that have their timing high enough for 93 octane where do you guys fill up at?
RE: Where's the 93???
ORIGINAL: 2000Si
91 octane will be just fine.
Most stations have either 91, 92, 93, and some even have 94. As long as the minimum you go is 91 you will be fine.
hey dude , sorry to be the one to let u in on this , it was a bummer for me also, when u get the predator u can only up timing to 12 deg total timing.... i wish u could go to 14 but inorder to do that ud have to pay another 120 dollars to a chipmaster revolutions or diablosport to burn u a custom tune that has 14 deg avalable as an option... i plan to do that soon enougn, and get a more agressive tune built at the same time... till then i just isntalled a 12 deg timing and diablo tune that comes with the predator... good luck
ORIGINAL: kubball2005
ORIGINAL: GT1999
