MSD Ignition, or Plasma B
Old Sep 29, 2003 | 08:10 PM
GSXRIntensity's Avatar
GSXRIntensity
Default MSD Ignition, or Plasma B
<FONT face="verdana, arial, helvetica" size=2>Which is the better modification, or does it really matter? Does one offer something the other does not, or what?</FONT>
Old Sep 29, 2003 | 11:06 PM
03SVTcobraa's Avatar
03SVTcobraa
It depends on how old the car is. On a newer car, MSD Ignition isn't going to be neccessary at all and won't help anything.
Old Sep 30, 2003 | 01:05 AM
GSXRIntensity
It's an '02 GT 5spd
Old Sep 30, 2003 | 01:08 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
wtf does a plasma booster do.. oh yea dont get an msd for your car, it won't do sh*t for you unless your runnin high compression and high octane gas</P>
Old Sep 30, 2003 | 01:27 AM
GSXRIntensity
So, basically your are saying that if I get nice set of iridium plugs...I'll be doing just what I would with an MSD ignition Stacker 8, and I'll be saving myself a ton of cash<IMG src=smileys/smiley5.gif border="0"> ?</P>
If that's the case, whenis an MSD beneficial to use? I've other mods as well if it helps:</P>
Magnaflow cat-back
Bassani X-pipe
Bassni ML headers</P>
March Performance pulleys #1190
C&amp;L M.A.M. w/trueflow pipe
C&amp;L upper intake plenum
K&amp;N air filter
FRPP 70mm throttle body</P>
Pro 5.0 shifter
Eibach pro-kit</P>
Ordering tomorrow<IMG src=smileys/smiley14.gif border="0">
4.10's
Modified cross shaft
AL DS
MM FL subframe connectors</P>
All that'll be left for me to do is to have a dynotuned chip. So, with that in mind...will the Stacker 8 help me???????? I am going to get my chip burned, so that it'll have my car running w/93 or better, so...help</P>
Old Sep 30, 2003 | 01:55 AM
Jugador1's Avatar
Jugador1
I ♥ Acer
i think he means you dont need it unless you're pushin some fat boost or something</P>
Old Sep 30, 2003 | 02:12 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Yea pretty much... see when you run pemium gas, the gas really isnt better than the regular (except maybe additives sometimes), its just higher octane, which means it resists detonation better than regular gas, which means its harder to ignite. Often times when you run premium fuel, no only do you not detonate or get spark knock, but you don't always burn all the fuel, wasting hp. THATS when an MSD will help you, when your not burning all the fuel. Also, at high rpm's (6500+) a stock ignition system may not be strong enough to get all the fuel burnt at those speeds, THATS when an MSD will help you. </P>
It also goes to show you that it can often times be a BAD idea to run premium fuel when you don't need it. Remember, if you want better gas, buy it from a better gas station, don't simply buy the expensive stuff because you think "you get what you pay for". The reason its more expensive has more to do with the fact that not as much of it is sold.</P>
Old Sep 30, 2003 | 03:21 AM
Snydaleid's Avatar
Snydaleid
http://www.fordmuscle.com/archives/2...er/index.shtml</P>
I hear it doesn't work. </P>
Old Sep 30, 2003 | 02:16 PM
GSXRIntensity
I'm a MOBIL user<IMG src=smileys/smiley16.gif border="0">
firehorse02
Nov 16, 2015 11:28 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
cjoracing
Jan 6, 2004 03:17 AM
GSXRIntensity
Oct 5, 2003 01:28 PM
