Noisy Pulley System
I've noticed that the pulley system on the 4.6 is very noisy! It sounds like a bad water pump bearing but when I check it it seems like all the pulleys/tensioners are making that same noise. Is this common?
John
John
ORIGINAL: contentsunderpressur
Yes, most of the time it's the tensioner or idler pulley that goes bad.
John
This is pretty noisy! I think I'll pull the belt off and spin each accesory by hand and see if it makes that noise. From what I can gather, it seems as though the tensioners seem to go out but at 14K? Also, since I'm going to have the belt off I might as well take off the A/C compressor since I'm not using it anymore. Does anyone know the size belt I will need to replace the longer one?
John
John
Do you think I should just go ahead and replace the pulleys with a UDP system since I'm going to be in there? Summits got a generic one for $100. Does anyone have experience with these?
John
John
ORIGINAL: Novanutcase
John
John
Keep in mind they won't solve the noise issue.....
