How high is your mileage? It could be your Idle Air Control sensor/motor going bad. Mine was acting up, and I replaced it for 40 bucks and now everything is smoot, right at 800 rpms at idle.
i got 63,000 mile on it and the car is running at normal temp and it still does it. sometimes at a hard stop then sometimes at a easy stop then some days it wont do it at all
You might want to try cleaning the area around the throttle body plate. My car was doing it quite a bit at around 80K. I found that by reving the engine by hand in the engine compartment I found that the plate was sticking a bit. I took the intake hose off, sprayed a rag with carb cleaner and wiped out all the garbage that was making the plate stick. The small ring of buildup you get causes a seal to form and can choke out the motor at idle.
When you're cold, your throttle is more open than when warm so theres is no 'seal'
